SV6 VE SII Oil in air intake and throttle body
Discussion in 'General' started by elshonno, Oct 11, 2014.
  1. elshonno
    elshonno Member
    This car just had a service 3rd since coming off the factory line. Today I pulled off one of the hoses and discovered a **** load of oil. I pulled off the ir intake from the throttle body and found about a tablespoon of oil as well. What do you think considering its still under warranty, shouldn't this be discovered in its 3rd service??
  2. VS_Pete
  3. ari666
  4. Grennan
    Glen Waverley, Victoria
    VE SSV G8 Sportswagon
    The PCV system is working as intended.
    If youre concerned about the amount of oil in there, use a catch can. But a teaspoon sounds perfectly normal.
  5. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    Average service doesn't involve taking off inlet piping or looking at the throttle body (just a filter change), that's probably why they haven't discovered it. If it's still under warranty ask Holden, you won't get a definitive answer here.
