SV6 VF Wagon - Mylink questions
ybl8te
calis vn v8
Hello Everyone,
I spied a mylink + satnav for sale, but upon inspection it does seem the faceplates are different from non-satnav to satnav - would this be correct?
If so, is this still plug and play with the VIN code etc?
Current Mylink, where RPT & DEST are say FAV and TONE and of course no NAV.
Below: Mylink + SatNav (VF Holden Commodore Series 1 (2013-2015))
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
No not plug and play as sat nav unit has extra plugs in it
stooge
wa
Turbo Alpaca
Yes it is plug and play.
You will need to buy a gps ant off ebay with a fakra plug for the sat nav.
You will need your vin flashed to it.
The buttons have different functions for the sat nav so make sure you get the screen, button module and base unit and you will be good to go.
Just keep in mind that the button functions are programmed into the screens logic board so if you change the screen make sure you change the button module too.
