SV6 wheel squeak?
Aestysu
Vn
Wheel started squeaking a little while back, maybe 2 months ago, i got car serviced, new brake pads, etc.
Wheel is still squeaking, no idea what it is, maybe the bearings? Brake pads are about 2-3 weeks old. I think its only the front right.
Squeaks nearly all the time, sometimes it stops, squeaks when im goin 10km/h or 100km/h doesn't matter.
Heres a video i recorded, sounds exactly like that, any ideas?
Untitled on Vimeo
HamaTime™
VIP Member
C Class AMG
give everything a spray with wd40 wheels brakes that should fix the squeaks
Mate are you ok in the head? WD 40 on brakes? They'll slip like a mofo, pad will barely if at all bite the rotor!
ffestival
Banned
67
Darwin
Ford WB Festiva
it works with my festiva, i spray wd40 in the rear brake drums and on the front brakes and it stops the noises for a while
MAG00
VY S2 Calais
Cause lubricating a part that is designed to slow the entire car through friction is a bright idea...
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
lol @ spraying lube on brakes.
Does the noise go away when you apply the brakes?
55ZED
Maryborough QLD
WL Statesman
This is probably caused by the pads chattering, there is something like hi temp silicone that
can be applied to the back of the pads where they contact the caliper piston.
Repco or a good brake repair workshop should be able to supply it.
55ZED
Maryborough QLD
WL Statesman
Also check the pads are fitted correctly, there are flat spring bits riveted to the pads, one of these may not be sitting
in correct position and may be rubbing on the disc
Aestysu
Vn
Yeh the noise stops when I brake.
Edit.
Also, my mate said when i gun it, my car smells weird, he said it smelt like the stuff you out on an exhaust to get fingerprints off or something?
Is that anything to worry about?
MY VZ
VZ Executive
maybe your rotors are warped
Aestysu
Vn
nah dont think so.
Also, just went to a mates to get him to sus it, said its the back not the front.
