Sv8 tail lights to Calais tail lights
Claudiabatten_
SA
VZ SV8
Trying to figure out what I will need to do to fit Calais tail lights into an sv8 vz. I know they won’t fit with a straight swap so what can I do? Has anyone done it before?
Fu Manchu
WA.
You change the bumper as well.
Fu Manchu
WA.
No. Wait, that’s VE. VZ should be a straight swap.
Whiteshark68
Queensland
VY Berlina Series II
Are you sure? i was aware that in the vy series the tail lights in the berlina and calais are larger and thought the vz would be the same
Fu Manchu
WA.
If there is any difference, it's not that they don't bolt on. They will. Holden didn't make sheet metal different for Calais. The difference will be how far down they go. To which, a Calais bumper is required.
Whiteshark68
Queensland
You are most certainly correct there i posted before i looked at the back of the car and on further investigation i think sv8 tail lights are the smaller executive size as such a rear bumper swap will also be needed.
Drawnnite
Obviously Unsensible
2000 Vs Ute
Do the Calais ones have the reflectors in them?
From memory thats why the Calais also had a different rear bumper to make it ADR compliant with the reflectors.
Having a quick look on Holmart they do indicate that the Calais/Berlina ones are bigger than the exec ones.
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
Calais has reflectors in the bar. light is slightly bigger so either cut your bar to suit the difference or buy a Calais bumper
