swap my vr 3.8 series 1 for a vs series 3 supercharged engine??
Discussion in 'V6 Development And Modification' started by oltronic, Jan 22, 2011.
  1. oltronic
    oltronic New Member
    vr commodore
    hi i was looking at doin a swap of engines in my vr 95 ute from a series 1 3.8l to a suercharged series 3 3.8l just wondering if anyone out there could let me know what im sort of in for i was going to use my t5 gearbox out of the ute and i know i need to change the exhuast but not to sure from there any info would be great
  2. oltronic
    oltronic New Member
    vr commodore
    anyone help
  3. soop
    soop Banned
    Smithton, Tasmania.
    2003 SS Commodore Series II
    You'll need everything from the donor car.
    Engine, loom, dash, ECU. Probably the engine mounts too.
    Someone will be able to help you more
  4. MACE
    MACE Well-Known Member
    The exhaust should bolt up.
    You can run a manual box behind a supercharged 6 (L67) however the flywheel will need to be mirror balanced to the flex plate from the L67 engine.
    http://forums.justcommodores.com.au/v6-development-modification/63206-v6-crankshaft-info.html
    As for the wiring, you can get away without having to swap looms :D
    The main catch is that you'll have to get a custom tune done and that you have to run the VR inlet tem sensor, swap over the knock sensors (I think) and lengthen sections of the loom for various items etc. All in all the job should take a little longer then a normal engine swap, where as if you change the loom the job becomes a lot bigger.
    I've done this conversion myself, except it was an auto ecotec into a VR auto. Drove well without a tune, in your case though it will definitely need a tune
    Hope this helps
    Cheers,
    Steve
