swap VN and VR rear axle?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by savage1987, Nov 20, 2008.
  1. savage1987
    savage1987 Donating Member
    VN V6 and VR V8.. what's needed to swap the axles over?
    Minispool into the VN open centre ----> into VR 5L
    LSD from VR ------> into VN V6
    Simple swap??
    Sam
  2. Zuicider
    Zuicider Banned
    Stonedville
    Set of thongs
    the whole diffs? just the axles or just the centers?
  3. centy
    centy Member
    Vp series 2
    whole diff is easy enough as long as both are solid.
    changing centres requires a lot more skill and money for parts.
    wap the whole diff is by far the easiest.
  4. AirStrike
    91' VN SS
    As mentioned if both solid axle just swap the whole thing disc to disc, easiest way.
  5. savage1987
    OK wasn't sure if the VR one was longer because of the pumped guards.
    I'll swap the entire lot over if it's that easy.
    Never done rear discs, I assume I'll have to change them over as they're different sizes..? Are they different sizes? VN s1 V6 and VR BT1 5L
  6. AirStrike
    91' VN SS
    No it's the same, like I said just swap the whole thing. Unbolt the tailshaft, disconnect the brake lines and unbolt the suspention components.
  7. savage1987
    OK. Just need some diff oil and i'll get onto it!
