WickedGoat
- Oct 26, 2020
- 109
- 146
- 43
- Age
- 49
- Location
- Lebanon, MO USA
- 2004 Pontiac GTO 5.7 LS1 6 speed
I finally wrapped up the JHP gauge install. Part of this project was to swap the instrument cluster overlay to match my gauges. Swapping a 2005 GTO cluster into my 2004 GTO would have been very difficult and time consuming and I didn't want the mileage screwed with. So I bought a used 2005 cluster on eBay for $60 USD.
I took the cluster apart and removed the needles and overlay. Then, I removed the cluster from my car and did the swap. Before I pulled the cluster, I made note of the needle positions so I could get them back on accurately, or close to it. Very easy swap. After that, it was a matter of programming my cluster for the higher red line of the 2005 overlay, and while I was in there, I turned the factory shift light on and set the RPMs for it and I rescaled the temperature gauge to act more like a real gauge. The program is available for free... VZClusterMod is it and it on LS1GTO dot com. All you need to do is buy a cable or make your own, download the program and have at it.
My stock 2004 instrument cluster with the JHP gauges...
Stock 2005 overlay now installed...
Stock 2005...
Now everything matches and the shift light is pretty cool. I'd like to fiddle with the cluster a little more and turn the lighting intensity up a bit. There are things you can do but what I have done is the most important to me.
Stock 2005...
