Swapping out stock steering wheel - Help removing please!
EdPreece
Tamworth, NSW
2003 VY SV8
Ok so I've bought a SAAS wooden wheel with a boss kit - which hopefully will arrive in the mail on Tuesday.
I was looking at the standard wheel which is in the car now and was wondering how the hell to remove it. I saw two bolts on the bottom of the wheel - are these all that are holding it in?
When I'm removing it - do I need to worry about the air bag going off in my face?
Do I just yank it off or should I wiggle it gently?
Anything else I need to do or not do when I'm taking the old one out?
Thanks in advance for your help,
Ed
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
If it has an airbag you cannot legally swap it out.
VR38
VB SL/E
^ As above, it is a defect and will not pass rego inspections (if checked correctly).
Also the air bag WILL go off in your face if you do not remove it correctly.
EdPreece
Tamworth, NSW
2003 VY SV8
Serious? Ah great just wasted a hundred bucks haha. What if I got an engineer's cert. for it?
iChris
Perthvegas
tweet tweet.
it's illegal in every state I believe to remove, tamper with or disable factory installed safety systems in cars.
wraith
Demonicaland
tweet tweet.
This man is on the money.
VR38
VB SL/E
It is covered by the ADR identification plate mounted in the engine bay, it is part of the Australian Design Rules that covers vehicle occupant safety restraints fitted to the vehicle.
Number 29 from memory.
Worst case scenario would be lending your car to someone to drive, them having a fatal accident and you fronting the corners court to explain why you remove it.
K-BAGZ
De Plane! De Plane!
Far North QLD
VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
Purchase a wood style steering wheel cover. Problem solved.
EdPreece
Tamworth, NSW
2003 VY SV8
Does the same go for swapping out the front seats? I want to put in some racing-style bucket seats cause my brother has them in his hilux and they're super comfy so I would like some...But do the original seats have airbags in them?
