swapping standard cluster to hsv 250k cluster
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by skid2leave, Feb 25, 2012.
  1. skid2leave
    skid2leave New Member
    VS Berlina 5.0
    hHey guys, just bought a hsv cluster (250 speedo) out of a vs clubby, just wanted to know if is a simple swap into my vs berline 5.0.
    Thought id ask here before i went for it.
    cheers
  2. skid2leave
    VS Berlina 5.0
    no ones done a conversion? ill see how i go
  3. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    If you already have a level 3 which I'm sure you will it should be fine. Do you have a 60 or 80L tank? You will have to switch the fuel gauge switch to read properly as the clubby has an 80L tank.
  4. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    Yep it'll go right in and should work a treat. :)
  5. wraith
    Demonicaland
    Thanks for confirming level 3 guru :p
  6. skid2leave
    VS Berlina 5.0
    yep got the level 3 cluster, its out at the moment. Oh **** forgot about fuel, might try and chase up a long range tank, cheers mate youre a lifesaver
  7. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    VS V8s have the same size tanks do you don't need to make any changes.
