Sway bar change
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by madsav, Jun 23, 2011.
  1. madsav
    madsav New Member
    your ass
    your ass
    Hi guys, i know there is a slight diffrence between the vx and the vt fron sway bar,
    Just wondering if there is a way to change my vt sway bar to a vx one ?also would there be any diffrence in the control of the car?
    its for a vt ss v8 2000 model
  2. GEN3RATD
    GEN3RATD 100% Teflon
    Cannington, WA
    VE Maloo
    get a whiteline 30mm front swaybar, i noticed that my SS handles much more confidently and the front end goes straight where i point it
  3. madsav
    madsav New Member
    your ass
    your ass
    Cheers mate, what price did you pay for it?
  4. GEN3RATD
    Cannington, WA
    VE Maloo
    i was quoted $945 for a front 30mm adjustable and rear 20mm adjustable whiteline swaybar installed, apperently its a **** job so i got a suspension place to do it. would probably be $200-$300 for just a front one
  5. 04VYSS
    04VYSS New Member
    Perth W.A.
    04 VY SS
    Did you have Pedders do it?
  6. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    VT V8 models had a 25mm bar except for VT SS models which had a 26mm front bar (not sure about FE2 option). VX models all had 26mm bar as standard except for FE2 option models which had a 27mm bar. So to get any benefit (since you have a VT SS) you would have to fit a bar from a VX model that had FE2 fitted.
  7. GEN3RATD
    Cannington, WA
    VE Maloo
    nope, WA Suspensions. i know the owner, so i got it cheaper. $945 was what i was quoted sorry
  8. acarmody
    acarmody Donati..Whoa Green
    VX Berlina
    I believe that to do it you have to either A) remove the engine, or B) drop the crossmember. Both are pretty big jobs.
  9. GEN3RATD
    Cannington, WA
    VE Maloo
    definately have to drop the cross member, thats why i got a mechanic to do it
  10. madsav
    madsav New Member
    your ass
    your ass
    What about the d shaped bushes, to replace them do you still have to drop the crossmember? In a vt with ls1
  11. jamesjgts25t
    jamesjgts25t New Member
    180sx
    I'm pretty sure you can get to the d-bushes through the engine bay but not 100% sure. I will bw trying it this way soon hopefully.
