Sway Bar Link Pins
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by mischa, Dec 19, 2008.
  1. mischa
    mischa Donating Member
    Ruse, NSW
    355 VN GRP A REP
    How do i know when ive done them up tight enough?
    Sorry if this is posted somewhere i dont have time to do a good search cause im running late and the cars got 2 wheels missing :p
  2. stocky
    stocky New Member
    if aftermarket, ive read that they just get tightened up enough for two rubbers to start pushing against each other. thats what i did with mine and no problems so far
  3. Morton
    Morton For external use only
    Fairstar the Funship
    Don't forget, you should ideally tighten them with load on the suspension :)
    But yes, as tight as is "sensible". Not so tight that you go red in the face, but a decent effort.
  4. mischa
    Ruse, NSW
    355 VN GRP A REP
    By load dose that mean having the car on the ground, how the hell do i reach them then? :p
    Anyway just done them up so i couldnt squeez the rubbers with my hand and then some :)
  5. Morton
    Yeah, car on the ground. Otherwise they're tightened up out of shape. You get under there by driving the front of the car up onto ramps, or lowing the front wheels onto some blocks of wood. :)
    Or, suck the belly in and squeeze under there like I do :p
  6. mischa
    Ruse, NSW
    355 VN GRP A REP
    Should be able to do that, im small enough :p
  7. padrickz88
    padrickz88 Rick =]
    sunshine, melbourne
    VN V6, nothing special
    but your a stick :p lol
    i done mine up "fairly" tight, pretty much what morton said before...
  8. mischa
    Ruse, NSW
    355 VN GRP A REP
    Yeah well i pretty much have to do it without ramps, my ramps dont agree with my front bumper :p
  9. Morton
    Drive the car up onto short wooden blocks before the ramps :)
    Yes, yes I am. That's how my cars go faster :)
  10. greenfoam
    greenfoam New Member
    VP Executive R-spec
    That's what does it for me too, you can't bet the guy next to you if he's got the same car and weighs 50 kilos less, even the flawed Human version of phsyics doesn't allow it, as for ramps. Last time I had to get my VP on ramps it took lots of wheelspin, some sideways action down the hill, planks of wood, cardboard, mowing the grass and finally after an hour a big run up and some braking skills before I got it on
  11. centy
    centy Member
    Vp series 2
    nah mate just do them up till a little after the bushes startto clamp. I spat a set of nolothanes out the side buy do them up tight, well firm by my standards.
  12. Andrew426
    Andrew426 Active Member
    New Plymouth, New Zealand
    VP calais, VR Berlina, VJ valiant, BG5 legacy
    I think the instructions that came with mine say go till there is no play left in them, then a third of a turn more. Or to 20 newton metres.
    Mine come loose so often that I am able to crouch down beside the car, reach around behind the front wheel and tighten them without needing to crawl under the car. Also - its a good idea to put an extra nut on (like the nuts off the ones you just removed) and tighten it against the nut on the link pin to lock it shut. Nylock nuts do sod all - mine always work loose.
  13. Morton
    Yes, but the rest of us aren't trying this stunt on a waterlogged field :p I know this comes as a shock, but some of us have sealed driveways ^_^
