Sway bar weight trade off?
CJAff
Shellharbour
VY II Acclaim
I'm looking at upgrading the front and rear sway bars on my VY, but I wanna know which way I should be looking. I've got two questions:
1) What is the weight (and general specs) of the standard sway bar?
2) Should I prioritise the front or rear sway bar (if I should prioritise at all)? The front seems more logical to me.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
The weight of the sway bar makes #### all difference to performance if that's what you are worried about.
Do you do circuit work?
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
Size matters, the bigger the bar the better, and if you want it to drive like it is on rails, then go big on front and rear, as abba says nuff said really.
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
Yeah not that simple.
Jesterarts
Your freedom ends where mine begins
2010 Nissan X-Trail ST-L
Different sway bars needed for different application. Bigger is not always better. As with all things, its about finding the right balance for application.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Too big a sway bar will work against the spring rate and shocks. You need to match everything to the application. Having a car that "corners like it's on rails" may be good for the track, but unless you run racing compound tyres, it's no good for the road. You need some body roll to make the suspension work and keep the tyres at the optimum angles for the correct contact patch.
CJAff
Shellharbour
VY II Acclaim
I'm just looking to eliminate some body roll and improve steering response. I don't really thrash it around corners.
I'm looking at the 30mm front and 18mm rear Whiteline sway bars.
richardpalinkas
Blown Alloytec
Gold Coast
Raptor Impulse VZ SV6
Just get the adjustable white line ones, that way if its too soft/hard you can change it
