Hi guys im about to put a manual into my ss i have most of the required parts like plastics for the console, box, x-member, pedal box & cable, clutch and all bolts required.. but i am not sure about the ecu and associated looms.. i have been told that you just need to find the reverse light wire on the auto loom and modify to the reverse light switch on the box??? or do i need a manual loom also the ecu is from a vs ss will this fit into the vr as vs had alot more senors than the vrs did? any help is apreciated thanks guys
do a search, or just look in the how-to's. Theres a whole thread there dedicated to this conversion and will answer all your questions. EDIT: yep its there on the first page. The complete vn/r manualconversion guide
