Gilly91
- Feb 6, 2010
- 81
- 51
- 18
- Location
- Wollongong, NSW
- VS Ute
Hi,
I have a VS Ute with a very noisy gearbox. Not sure what treatment it had by the prvious owner but im guessng not too nice. There is a noise coming from the gearbox that sounds like something is scraping on something each revolution it makes.
I have put the car on jacks, put it in gear and got under it to have a listen and it sounds to be coming from the front of the box.
Also, it happens in 1st and 2nd the worst but im not sure if that is just because you only dont notice it in higher gears. Reverse is just as bad as 1st. Sometimes when in neutral and the clutch out there is a bad constant whining noise and im guessing this depends on the orientation of the gearbox when stopped because it only sometimes happens, The whining goes away if you put the clutch in. The once per revolution grinding/scraping noise can also be heard when rolling with the clutch in or in neutral.
The shifter seems really loose as well when in gear, like it feels when in neutral with a normal gearbox.
Just wondering what I am up for, and whether I can fix it myself. I am assuming the answer will be a new gear box, but just wondering before I go put on in or get one put in and turns out it is something else. Would it have anything to do with the driveshaft centre bearing?? Because im a bit suspicious of it...
Thanks heaps.
Thanks heaps.
