T5/Getrag manual swap?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by sganro, Apr 12, 2007.
  1. sganro
    sganro i speak before i think
    NQ
    yet another VS
    Ok my brother has a vr manual ute and the gearbox is half rooted.
    He has got access to a getrag box out of a VT and wants to know if it can be put in his VR? (changing the bell housing and what not to bolt onto the buick)
    Has anyone tried this conversion or is it not do-able?
  2. Murdoch
    Murdoch Active Member
    VF II SSV Wagoon
    getrags use a dual mass fly wheel. The VR would have a solid fly wheel.
    I would call a transmission expert and ask whther they are interchangable. Also the getrag clutch is fluid operated, so i guess that would need to be looked at too.
    Malwood automotive would be a good start to ask.
  3. Jesterarts
    2010 Nissan X-Trail ST-L
    on the note of the dual amss flywheel...
    If he ends up finding out it is interchangeable the FIRST thing he wantsw to do is replace that POS with a rigid flywheel!
    I cannot wait until my clutch n flywheel f*cked up again so i can justify upgrading to a HD clutch and rigis flywheel...
    Mind you i have my clutch n fly replaced in March of 2006 and now i recon its on its way out again... slipping and so on..
    Their good if u drive the car like a 90yo asian but if ur gonna give it abit it will not be happy!
    Good luck with it!
  4. LowVp
    LowVp VP Enthusiast
    Dalby, Qld
    VP Ute 3.8T T56
    getrags are a POS, stay with the T5 and the dual mass flywheels are expensive to do when replacing a clutch
  5. BnSuter
    BnSuter Meow Meow F**kin' wow
    Victoria, I'm from the country an I like it that w
    VS S2 S pack ute
    ECO-TEC with getrag box.
    Does any one know of a company that builds a solid fly wheel for the eco-tec motor...as I have had trouble with my clutch i'm putting to much power through a dual mass fly wheel an clutch. I've been an seen a mechinist about moderfing a buick fly wheel to suite but they advise not to change the crank bolt patton from a 6 hole fly wheel to a 8 hole. Is there like a kit you can buy with a solid fly wheel an a heavy duty clutch or even a twin plate.
  6. immortality
    Sth Auck, NZ
    didn't the s1 VS commodores have the T5 box. so there must be flywheels avail to suit right
  7. Fekason
    Fekason Fekason
    Penrith NSW
    Available from clutch specialists.
    Solid flywheels and heavy duty clutches are available from specialists such as Exedy (spelling may be wrong).
    Looked into one a year ago. Cost of the swap was about $1,100, cheaper than a replacement dual mass flywheel and clutch kit.
    Get in touch with your nearest independent clutch specialist.
  8. BnSuter
    VS S2 S pack ute
    sweet thanks, when i replaced my clutch last time exedy told me i had to replace the fly wheel instead i buffed it to get the heat stress out an checked the tension on the springs....there has been no problem so far only problem is it slips a lil bit when you snap 2nd or put heaps of power through it eg. 2nd gear rev limiter. Dual mass fly wheel combination with a single plate isn't good enough for 156rwkw out of a v6
