T5 is playing up
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by shanhsv, Oct 5, 2011.
  1. shanhsv
    shanhsv Luvo
    Muswellbrook, NSW
    VSII Calais V6 & VSII Senator 215i
    Most times when i put the clutch in,the gearboz starts making a weird noise and i get a strong vibration on the gear stick,it all goes when i let the clutch back out. The car still drives ok but i dont want to stuff the gear box,whats its problem?
  2. 304runner
    304runner ( .Y. )
    Central Coast NSW
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    You will need to replace the oil. Or at the very least top it up. A thinner grade should suffice.....
  3. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    If it goes away when you let the clutch up, that would indicate that is a clutch problem and not gearbox related. You could have a thrust bearing failing...or the pilot bearing ....or the clutch pressure plate distorted....or the driven plate distorted.
    I'd get it up on a hoist and have a look....if that's not possible I'd take it to a clutch specialist or a driveline mechanic for their opinion. I wouldn't leave it too long as you can bet your bottom dollar it won't get better.
  4. Andrew426
    Andrew426 Active Member
    New Plymouth, New Zealand
    VP calais, VR Berlina, VJ valiant, BG5 legacy
    Dex2 ATF in a WC t5.
    Gearbox needs to come out. Check release bearing and spigot bearing. But probably best to take it to somebody who knows what they are doing (like a mechanic). As Hako said, its not going to get better by its self, but will probably get much, much worse if you leave it.
  5. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    Pretty much what hako said^^^^. I cant see the oil being the issue, but hey its cheap to rule out.
    As above, vibrations are bad. They shorten the life of everything, so get it checked asap.
  6. shanhsv
    shanhsv Luvo
    Muswellbrook, NSW
    Aww crap,cheers guys,i'll look into a mechanic today
