T56 gearbox service
RyanDZ88
35
Iluka nsw
VY S2 Executive 6c
Hi I have a 01 vx ss with a T56 manual 6 speed box with 213xxx and as far as i know its the original box.
This is the 1st manual ls1 i have owned all previous have been auto and want to treat it rite and give it a full service.
Was reading that dex 3 is the best is this true as I'm a lil sceptic about putting ATF in a manual?
For the most part it seems pretty straight forward
Release from bottom bolt
Fill to top bolt
Now what I'm not sure about is I seen mentioned that to get the full 4.4L in you have to remove revers sensor.
Is removing the sensor a easy job and where is it and how do I remove it to get the extra 400ml in?
Big Thanks in advance to any help
Tatiana
We should have sushi Carol
Staff member
Land of the free
Equinox LTZ - runs on cocaine
Moved - the how to section is not for questions.
vr304
Auckland, New Zealand
2007 ssv manual
These boxes normally have atf in them mate that’s how they come from factory but Penrite pro gear 70w75 is a far better oil to run in them it’s a light manual gearbox oil specifically for these gearboxes and to replace it just dump the old stuff and fill the whole lot thru the reverse sensor hole just need a ring spanner to remove it I forget what size
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
yup.. Penrite Pro is the only stuff that should go a Tremec box
had it in my VX SS, now have it in my HSV Clubbie
