Hi all, went and wired in a tacho today, but there is a small prob, it idles good, but then when u recv it it freezes at 1500, so i took it for a drive thinking it may not work in park, but as oon as u give it acceleration it drops to zero, now iv tested with 2 tacho's and same prob, but all the wiring is fine, i was thinking its loosing signal by the time it reached the tacho, could this be it...
i had the same problem on my tacho, (which i pulled out cause its over excessive for a stock six but least its a manual) try checking that it getting a good earth try double checking all the joins. mine worked after i earthed it better.
does anyone know if the execs have a tacho wire behind the dash, or do u have to use the one following up the right hand side of the motor (proper tacho cord)
yeah they do. brown wire with red stripe. pop off the cover under the steering wheel and find the loom going upto the dash, unwrap it and splice it in to that wire. thats on a exec vn be shore to keep it connected so it still goes to the dash or ecu.
hey well we got the tacho working, was a bad earth but my mate vrought a tacho today and wired it up, didnt work, then we tried it on my car and didnt work (has a working tacho) so we went and swapped it for the same one but a new 1, neway same prob, on both cars, has a back light and is wored fine but the version tacho just wont pic up ne help...
yeah but we wired his tacho into my car and it worked but when we hook his into his it doesnt work, and when we hook mine into his it works, its just the 1 tacho, and we have swapped it for a new 1...
lol i will return the cheap one cause i just one this on ebay http://cgi.ebay.com.au/ws/eBayISAPI...30011333295&rd=1&sspagename=STRK:MEWN:IT&rd=1
