tail lights turning off when brake applied!?!?!?!?!?
plAythiNG
Liverpool, Sydney
VN Executive V6
hey guys, i am ahving problems with my rear, drivers side brake lights. i turn on the lights, all four lights turn on, but as soon as i apply the brake, on the drivers side, the bottom light will turn off. how do i fix this problem, if i open up the boot and jiggle the socket around, the light will come back on, when the brake is applied, but after a bit of driving, it turns itself back off again, is there a fix to this problem? cheers
Immortality
Staff member
Sth Auck, NZ
yep, you gotta find the loose wire causing a short circuit.
Shortstuff
Random
2016 Golf GTI PP
Or it could be a faulty globe. My lights used to do that and they were fine once I replaced the globes.
WAGON MAN
Gas Sleeper
North Coast , NSW
VX S2 Berlina Wagon with Phreddied bits.
Sound like you have a dogey globe......
Bax
Projecting
40
QLD
Nothing
Fix up the wiring.
SweetWagon
booosted
35
Springwood NSW
VS Berlina Wagon Supercharged
Yeah sounds like globe to me 2, the 2 taillights run off the same circuit, so if it were wiring both lights would go out.
Cheap6
VP Exec
Could be bad earth. Most likely tailight socke t on that side is corroded due to water entry into the tail light. New sockets and harness will be the permanent fix. And fixing the water leak, usually the lamp assembly itself.
Bax
Projecting
40
QLD
Nothing
two taillights run off the same circuit but when he wiggles the connection at the bulb it drops out.
its either the bulb or the connections with the wiring. my guess would be the wiring @ the connection to the bulb- change the bulb with the other one if you want to check that.
