taking LPG system off one car for another?
comtim
50
VN
I have a VN on LPG. Im planning one getting a one tonne tray of some sort. Is it possible to take the LPG system of the VN with the view of fitting it to the new car?
Is it a big involved job? thanks for any info...
potshots007
37
Mildura
VN series II custom :) and VZ exec
depending on what sort of ute, yes it is possible and you might be able to use the covertor and a few lines and stuff, but i would doubt the tank would fit and the mixer would be different unless you were running a V6, always a good start thought to have some of the items needed, makes it cheaper in the end,
well thats my thoughts
cheers, nick
JD
Donating Member
37
Deep South, SA
www.ccgm.au.tt
1.6L Turbo Holden Croooooooooooze
i think it has to be re-checked once its installed in a different vehicle as well
PaRaDoX
Because Racecouch...
Melbourne, Victoria
none
first of all you have to write to the alterntive fuel board requesting compliance plates,(this came in last weeK) with a installer once the letter has been responded to then you can swap it over
the systems should be cross compadible but the VN is injected so.. if the 1 tonner isnt then you'll have to get a new system.. the tank should work
id look for a carby gas system and leave the vn on lpg to be honost.. its alot of work
