right ya first need to take out the bottom of the seat by grabbing behind it pulling it up jiggling a bit and it should come out then undo the screws at tyhe bottom of the two back seats (either side of the pull down seat) then once there undone pull the seats upwords they will come of then there are six little plastic screws that nees to be undone (three across the face behind the seats and three are ontop of the parcell shelf then if you bend a little in the middle it should slide straight forward hope it helps you
