Taking VS Key apart
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by TightAs5, Sep 2, 2010.
Tags:
  1. TightAs5
    TightAs5 New Member
    Hunter
    VR
    Yes old story but trying to get key apart to replace rubber buttons, please dont answer post if your reply will be no you need a new key because it isnt true and they can survive more than two hours without a battery and dont need reprograming.... I just want to know what glue they used to seal the buggers as:unsure: I want to take it apart without damaging the case
  2. SlickVS
    SlickVS New Member
    VS Executive 3.8
    Hey mate I just swapped my buttons over yesterday! Start by removing the screws and key which will make things a lot easier, then you should be able to spread that end slightly and slowly work your way around until you almost reach the end attached to your key rings. If your lucky the glue will "crack" and the key will pop open, it took quite a bit of force to open mine so be careful. You may have to place a couple drops of superglue on the two inner sides of your key too otherwise it will just fall apart again. :)
  3. Super_Low 91
    Super_Low 91 ┌∩┐(◕_◕)┌∩┐
    Aussie
    Not a Commodore
    you dont have to "break" open the key at all,, use a small knife and cut the old buttons out then the new ones just push in,,
  4. SlickVS
    SlickVS New Member
    VS Executive 3.8
    This is true, and probably a good idea. Although it's a lot neater if you can do it by opening your key.
  5. Super_Low 91
    Aussie
    Not a Commodore
    If done properly and carefully it will look close to factory where as trying to pry open the key you could scratch it,, even the instructions that come with the buttons say to cut the old buttons out. (il have to double check that but almost certain)
  6. MADDNE33
    MADDNE33 New Member
    1999 vs ute series 3
    just put new buttons in, got half way threw ripping the key apart and found out they just pop staright in :/
  7. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    Where do you buy the new buttons? Holden I take it, and how much please?
  8. doms1
    doms1 New Member
    BANNED
  9. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    K cheers......
