Tapping Noise
B
Bloka
Guest
There is a tapping noise when i start the car, in the engine bay. After it warms up it goes away.
I think it is either one of the Lifters sticking or one of the tappets has goneeeeee?
Any help on this one??
Thanks
Bloka
vee ka
'85 HDT VK SS, '03 Liberty GT, '06 Forester XT
Thanks
Bloka
i reckon its probably one of your lifters, mine does the same thing ( but mines a carb 5.0 ) :thumbsup:
B
Bloka
Guest
Is there anything you can do to make it go away or will it just sort itself out?
A
Andre's SS
Guest
Its just cold ,when the oil heats up ya said its fine.
Its a Holden get used to clunks and grinds ;)
As long as it starts and goes hard shes all good :)
Don Sutton
74
VS Commodore Acclaim
1] How long does it take to go away?
2] Does it do this everytime the engine has stood unrun for 5 or more hours?
3] Have you done regular oil/filter changes?
4] Has it done a lot of k's?
If it takes more than 1 minute to go away and occurs everytime the engine starts after a long stand you should consider piston slap. A 6 cyl engine will stop in one of 3 places and usually random so if it were a tappet it would be also random as it would not always be holding a valve open and therefore no incentive to bleed down. Piston slap usually occurs at high k's but can occur at lower k's if the engine has:
overheated
had irregular oil changes so that the piston has worn
has a defective or undersize piston
Likewise if it is hydraulic tappet and bleeds down when holding a stationary valve open it can be caused by:
foreign material on the lifter valve
infrequent oil/filter changes
worn lifter valve seat
oil system draining of oil
slow to get oil pressure
B
Bloka
Guest
Thanks for that Don most helpful.
I have done regular changes on it. is due for one this wend.
It has done 118,000 so it should be fine.
It usually is there for about 1 min and then goes away once the car is heated up a little. It pretty much does it everytime that car has sat there for more than 5 hours yeah.
B
Bloka
Guest
Yeah did an oil change on the weekend and it all seems to have gone now.
Sorted thanks for the info.
Bloka
