Brett_jjj
- Oct 16, 2009
- 6,805
- 108
- 48
- Location
- Tamworth NSW
- vs commodore
For anyone interested, Ive found out some more stuff about Tech 1.I copied this off the web-
The are two versions of the Tech1 which were used by GM. The early ones are just a Tech1 the newer ones are known as the Tech1a. You can easily tell the difference. Tech1 has a 15way D PLUG and the Tech1a has a 26way HD (3 line) D SOCKET. The Tech1a also has a power socket and a RJ45 socket on the side for connecting to the RS232 port of a PC (the Tech1 requires an additional cartridge to add this functionality)
They are very much functionally identical for most tasks. The main difference is you cannot program a MSC (Mass Storage Cartridge) with a Tech1 unless you have the optional plug in communications module (with RJ45 socket). You also have to power the unit from the car (you can't power it on the bench!).Tech2 superseded the Tech1/1a . From what Ive read online on USA websites is that cars that have OBD11 plugs(16 pin) but use OBD1 protocols, eg VR/VS commodores ,need a special adapter,which apparently is still available in USA for $70US.
