Brett_jjj
- Oct 16, 2009
- 6,805
- 108
- 48
- Location
- Tamworth NSW
- vs commodore
Brand new programmed aussie tech 2 cards are $40 posted. Yes, the tech 2 has a brake bleed option for activating the ABS whilst your bleeding the brakes. You can also read/clear any ABS error codes.
On VX models, you can still flash up any ABS error codes on the ABS warning light, by bridging pins 5 and 12 in the diagnostic connector under the dash and then turning the ignition key to ON.
Here is a list of ABS error codes for VT to VZ model commodores. (ABS Codes can only be flashed up on the ABS dashlight on VT and VX models).
Code 12= Start up code/ system ok.
Code 21= Front right wheel speed sensor faulty signal.
Code 23= Front right wheel speed sensor short or open circuit.
Code 25= Front left wheel speed sensor faulty signal.
Code 27= Front left wheel speed sensor short or open circuit.
Code 28= Front wheel speed sensor frequency incorrect.
Code 31= Rear right wheel speed sensor faulty signal.
Code 33= Rear right wheel speed sensor short or open circuit.
Code 35= Rear left wheel speed sensor faulty signal.
Code 37= Rear left wheel speed sensor short or open circuit.
Code 41= Front right inlet valve solenoid.
Code 42= Front right outlet valve solenoid.
Code 45= Front left inlet valve solenoid.
Code 46= Front left outlet valve solenoid.
Code 47= Priming valve solenoid.
Code 48= Switching valve solenoid.
Code 51= Rear right inlet valve solenoid.
Code 52= Rear right outlet valve solenoid.
Code 55= Rear axle inlet valve solenoid/Rear left inlet valve solenoid.
Code 56= Rear Rear axle outlet valve solenoid/Rear left outlet valve solenoid.
Code 61= Pump motor or relay faulty.
Code 62= RPM signal incorrect.
Code 63= Valve solenoid relay circuit faulty.
Code 67= Stop light switch circuit faulty.
Code 71= Control module internal fault.
Code 72= Data fault.
Code 73= Requested torque circuit fault.
Code 74= Actual torque circuit fault.
Code 78= Incorrect optional coding.
Code 85= Voltage too low.
Code 58 for gen 111= Throttle relaxer PWM interface fault.
Code 62 for gen 111= RPM signal fault.
Code 64 for gen 111= Throttle relaxer control module position fault.
Code 65 for gen 111= Throttle relaxer motor fault.
Code 66 for gen 111= Throttle relaxer control fault.
