Tein Coilovers
jscottnjs
VT Senator 5L
Hi all,
I know its a long stot but would anyone have a manual for the Tein Super Street Damper coilovers? I have just bought some second hand and am chasing a manual.
_R_J_K_
Zenki S14
What do you need to know?
Do you know how many K's are on them?
jscottnjs
VT Senator 5L
Hi just need to know how to install, adjust etc.
They have 6,000ks on them
_R_J_K_
Zenki S14
You install them like you would any other shock absorber. Did they come with C-spanners?
jscottnjs
VT Senator 5L
Yeah mate came with c spanners
_R_J_K_
Zenki S14
Basically any video on YouTube will tell you how to adjust them, even the Tein specific videos or guides you find for Silvias should apply also as they pretty much mount in exactly the same way.
I like this method as it has a little more thought put into it instead of just using base adjustment to determine ride height. Basically you take the springs off and put the coilovers in the car, then put your wheels on, then jack the wheels up as far as they will go. If the wheels foul on anything (lock to lock included on the front) you adjust the base height until they don't. Then you put the springs back on the coilovers and adjust the spring seat collars to get your desired ride height.
Most of this won't apply to the rear because of the Commodore's separated spring/shock and swing arm setup.
This video kind of sums it up:
jscottnjs
VT Senator 5L
Excellent thankyou very much, appreciate your help
