Thanks man.Good job!
Nope, it's great around corners now, car stays really level and stiff as ****. Completelty different from the standard suspension.Does it roll much in corners now?
Yes, extremely. It's a completely different car to drive now, I'm really pleased.Are you happy with the way it corners?
Yeah, I will have to when I can. I'll be leaving the XA's on the stiffer settings, so I've been told it'll be a lot better with some thicker sway bars.Do you need bigger sway bars now?
Whiteline make an adjustable kit for VZ's
30mm front and 20mm rear.
That would make it sit flat in the corners!
