Temperature Gauge: reading?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Morton, Sep 20, 2007.
  1. Morton
    Morton For external use only
    Fairstar the Funship
    I'm just a bit curious about the factory temperature gauge on the VP Commodores. Does anybody know the range of temperatures it displays?
    eg: a reading of halfway - what sort of engine temperature would that indicate? And at 3/4 again, what am I looking at? I've had a bit of a looksie, but it doesn't appear to be covered :thumbsup:
    cheers in advance, guys!
  2. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    Yeh, 1/2 = the same as H-1/4 + (-)1/4 and also = C + 1/4 + 1/4
    isnt H = the suns operating temp? lol....
    imnot sure it is mesurable without an afteranrket guage..
    aZk.
  3. Pub247
    Pub247 Well-Known Member
    Melbourne S.E.
    Ford Fairmont
    No gauge is the same thats for sure my level 1 cluster just over halfway when really hot
    but my level 3 one gets just over a quarter at it hottest. if you knew the operating temp versus resistance of the sensor you'd might be able to work out an a guestimate.
  4. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Blue = good
    Red = bad
    Steam+knocking = really bad
    Engine stop = really really bad
  5. Morton
    lmao ^^ thanks for that, abba :p
    Usually I go off trans temp. If I can feel a LOT of heat coming through the bottom of the gear lever, then I assume I'm in trouble.
    Maybe it's time for an aftermarket unit ^^
  6. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    If you need to know the actual coolant temp then install an aftermarket gauge.
  7. Morton
    yeah. That way I know whether to worry about my temperature. Last thing I want to do is blow a head gasket :)
  8. CALAIS 6
    CALAIS 6 snowballing
    Adelaide,Tea Tree Gully
    98 Triton mini truck
    LOL not allwasy case yesterday coming along freeway ourr vs ute stopped broke down then started with bad knocking then shot out all it's coolant and oil and the gauge only was reading between 1/4 adn 1/2 temp now bottom end is gone adn it's all ceased
  9. greenfoam
    greenfoam New Member
    VP Executive R-spec
    ecotecs are even better than the early V6 at throwing rods out the block when the bearings wear out, it's a favorite party trick of both motors:)
  10. CALAIS 6
    Yeah i was fair impressed not really sitting at side off freeway for an hour then deciding she's rooted and drove it 3k's too mt barker lol and left it there
  11. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    I didn't say that it happened in that order. You just experienced the last two, but without the steam.
  12. Morton
    haha, well I'm decided that I'm going to chase an aftermarket coolant temp gauge. I'll look at some prices tomorrow. If anyone knows off the top of their heads, can I just splice an aftermarket gauge into my water temp sender wire? That would be so easy :)
    May also look into an oil temp gauge. I think they have senders that you adapt to your oil filter, don't they?
    Gotta look after this motor. Last thing I want is an overheating issue in summer. Hmmm... gotta run. Shouldn't be on here at work :D
    *runs*
  13. SweetWagon
    SweetWagon booosted
    Springwood NSW
    VS Berlina Wagon Supercharged
    nope you gotta get the correct sender for the gauge (should come with it) then you have to buy a t-peice for the original sender, (unless you dont want it to work anymore). Once that done just hook up acc and illumination to it. with oil gauges you can buy an adaptor that goes between the filter and engine. not sure on prices or where to get them so best bet is another t-peice on oil pressure sensor.
    visit street commodores, there a good how-to under TECH > Interior > Issue 101.
    Morton likes this.
  14. Morton
    Interesting - cheers for that mate :) I'll have a looksie today. Probably end up costing me close to $100 all up though... expensive >.<
    (pfft, still at work. )
