Tensioner Arm Replacement, How to?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by draco2, May 17, 2008.
  1. draco2
    draco2 New Member
    Tensioner Arm Replacement, Help?
    Can anyone tell me how to replace the tensioner arm as where the bolt goes into it is threaded. i have a wrecked vs which i can get parts from, but have no idea how to remove/replace the tensioner arm. any help would be awesome!
    car: vs series 1 exec
  2. ephect
    ephect Donating Member
    VS Acclaim V6
    u need to remove the alternator, then you should be able to see where all your bolts are, from memory there are about 4 bolts that hold that on. you'll need to top up your coolant levels afterwards. i cant seem to find my gregories...
    the tensioner pulley bolt is left hand thread. by the sounds of it, you have just done what i did 2 years ago :) i know the pain!
    someone should post up the bolt count and what needs to be removed shortly, as i cant find my manual
  3. draco2
    draco2 New Member
    if someone has the chapter from gergeries that would be awesome, or a step by step instruction would be nice. kinda need this info urgently, as i have work again on monday :S
    thanks guys
