Tensioner pulley- easing off tension
Discussion in 'General' started by Dr HaxZaw, Sep 30, 2011.
  1. Dr HaxZaw
    Dr HaxZaw New Member
    R34 GT-T
    So im changing the belt and i want to take the tension off... i've done a search but dont seem to be able to find any information on this
    Do you just take the pulley off it or do you need to take the tension off the pulley first? In which case how do you take the tension off it as i cant see anything obvious on it to do this?
    Its for an ecotec if it makes much difference
  2. elmaso
    elmaso Member
    VS berlina
    i am pretty sure it just the pulley then tensioner. but the pulley can be the up side of a pain in the arse to get off.
    why do you need to take the tensioner off though?
  3. ari666
  4. 383 hatch
    383 hatch Well-Known Member
    Cowes, Phillip Island
    Get a 15mm spanner on the bolt that holds the tensioner pulley on and turn it counter clockwise. This will rotate the tensioner and take the tension off the belt allowing you to remove it. Sit the new belt on and do the same again.
    That'll be $80 thanks, because i've recently been informed that mechanics shouldn't give out free advice. :p
  5. Dr HaxZaw
    R34 GT-T
    thanks for the replies fella's
    lol should have made me pay a deposit on that advice first... then i might have handed over the rest of the money lol
