hi i was just wondering if anyone knows wat the hose running the the tensioner pulley bracket is. and how hard are they to replace. thanks
It's the heater supply hose. Easy to change but you will lose some coolant and therefore need to top up and bleed the system when you are finished.
Just found today that the connection into the manifold end of this little hose has snapped off. Are there any recommendations on what to do to fix or is there a way to bypass this.
