Testing Alterrntor and battery
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Noy, Mar 1, 2009.
  1. Noy
    Noy New Member
    VN SS 5.0
    ey guys got myself a multimeter to test my alternator and battery got a few questions though as im not sure what the voltage is suppost to be on both alternator and battery.
    So what setting should the multimeter be on?
    How do I test the alternator for voltage?
    And what volts should be going through the battery and alternator?
    Cheers for any advice
  2. Vt-Brrrlina
    Vt-Brrrlina vp bt1 gts replica
    Perth, Western Aust
    vp bt1 5.0ltr full GTS kit
    put your multimeter on volts u only need volts with one decimal place eg 12.5 volts
    your battery should be around the 12 volt mark normal
    when car is running should be around 13 - 14 volts
    anything less than 13 and your car isnt charging
  3. axemurderer101
    axemurderer101 Well-Known Member
    Albany
    VY SS
    put your multimeter on 20 DC volts, DC is the symbol with a line with dots underneath and AC is like this ~
  4. Cheap6
    Cheap6 New Member
    VP Exec
    A fully charged car battery should read ~12.6V across the terminals with the car off. With the car running, the voltage across the battery terminals should read ~13.8V at idle and rise to ~14.0-14.2V (and no greater) if the throttle is opened a little. It should stay at that level if you switch on some of the electrical load like headlights and fan.
    If you put the red voltmeter lead on the bolt on the back of the alternator with the thickest wire attached to it and leave the black wire on the battery earth terminal, you should get very close to the same reading as you do directly across the battery terminals.
  5. h0Ld3n`VN
    h0Ld3n`VN New Member
    NO CAR ATM.. -.-
    this is correct, thats the readings what my volts gauge gives me
  6. pr0n
    pr0n It's A Me ' MARIO '
    Gladstone
    03 VY II S V6
    you can test your alternator by starting the car, turn the hi beams on then pull the positive terminal off the battery, if it keeps running you have a good alternator
  7. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    that is the best way to kill an alternator.
