However, what I am trying to get at, is in spite of all the above evidence, all the theory etc...why did it come out with a smaller (albeit 1kw) yield on the DYNO. If the fan in front of the car pushing air into the radiator and through the OTR, if the POD setup is better in terms of airflow and greater pickup of cooler air Why wouldn't it show on the tests?
Good testing there bud.
As i have always felt, LPG is purely for budget motoring when you use the mixer ring/ cone setups. They will never make power as they create a huge restriction in the intake path. A restriction very much like what i heard about the V8 brutes a few years ago (VU? series) they made much better power than the ford 302(?) so they put a restrictor 'ring' in the intake to cap the LS1s a few kw?? Anyway, in your situation, if you want to make similar power on LPG (as is on petty) you have to look at a direct injection setup. Something that i would be interested in trialing on my race car.
As for the CAI systems. The problem with enclosed pods is that they soak heat in the box. The OTR's do this also hence it comes down to which one can continuously flow the most efficiently while driving to negate the heat soaking effects.
I have tried both SC6 and enclosed pod setups. Nothing wrong with the SC6 cai as it looked stock and tidy. But as most v6 owners were doing this same mod, i chose to try a different setup for individuality and (imo) a neater look again. I tried the enclosed pod with a metal box, small 90mm air feed in the guard. Neat look but soaked heat badly. I developed it further.... Heat resistant matting on the inside of the box, and also a larger cutout in the guard (the size of a panel filter) and a scoop facing the front behind the bumper. i know not many ppl are keen on cutting holes, but this one is not visible at all and its not a load bearing panel.
Though it was a lot of mucking about, i now have a cai system that im happy with and has made a gain... if only 4-5 kw (with back to back testing). I can easily pull the headlight out at the drags to have a direct cold air charge to the pod.
Dont know if this will help much.. but its a slice of my knowledge
Good suggestion Bart, thanks very much for the tip! Appreciated.
Yeah people cut them back to open them up and also use a heat gun to open it up a bit as well.
If your intending to stay with the L67 set up i would recommend doing what is shown in the pic below. remove the plastic strip that cover the gap in front of the radiator (as shown in the pic) and use some sort of foam strips to seal the bonnet against the intake mouth. that way, when you do come to a stop the intake will continue to suck cold air instead of hot air from under the bonnet.
i also used a jig saw to cut about 1" of the front of the intake to make the hole bigger
