The Random Thread
keith reed
77
Raceview Qld
1983 vh v8 sle 2000 vs v8 ute 2012 ve11 redline
If a monkey hoarded more bananas than it could eat while most of the other monkeys starved, scientist would study that monkey to figure out what was wrong with it. When humans do it they are put on the cover of Forbes.
VZSSHawk
South Australia
VZ SS Ute & VF SSV Redline II
Random question for the random thread.
Nan & Pop’s bathroom has black mould on the ceiling, getting an electrician to put a new air fan in there, how to get rid of the black mould before hand though? Thanks.
VSYoot
41
Near Avoca Vic
VP Berlina. Blown VE SS. Crusty Valiants
How bad>?
It's nasty **** so wear a mask when cleaning it.
Vinegar is supposed to be good, bleach works too.
VZSSHawk
South Australia
How bad>?
Just some spots above the shower.
Enough for me to notice it.
hademall
Donating Member
67
VF CALAIS WAGON
It depends on whether the ceiling is plaster board or cement sheet lined. Unfortunately, mould is like a fungi. It takes a while to grow and ultimately becomes ingrained into the sub strata, which in most cases in a house is the plaster board.
Plaster board or gyp rock as it is commonly known, is basically made up of plaster and paper. The plaster is somewhat similar to chalk and therefore porous. So, unless protected in a wet and often steamy area such as bathrooms, it will ultimately absorb the moisture allowing the mould to grow.
Depending on how bad the mould is, will determine how you treat it. Firstly, I would try to dry the ceiling out as much as possible with a heat blower of some sort, (difficult I know, but the ceiling fan will help once installed) before doing anything else. I would then lightly scrape off any loose paint and mould, bearing in mind you don’t want to scrape off the paper of the plaster board. I would then give it a light wash down with sugar soap and then perhaps as VSYoot suggested, a mild solution of vinegar.
Once it has completely dried, I would paint it with a plaster board sealant before applying your top coat of acrylic paint.
Cement sheet (often asbestos in old houses) is a different matter, and something I would get the professionals in to do.
In the past, I have done the easier thing when the mould has been so bad. And that is to take the whole ceiling down and replace it. But I’m sure you won’t want to do that:)
VZSSHawk
South Australia
Yeah looks like plaster board to my uneducated eyes, haha.
Cheers Hade.
VSYoot
41
Near Avoca Vic
hademall
Donating Member
67
VF CALAIS WAGON
My daughter’s 2013 Mazda CX9 Luxury Model FWD has been written off. She is looking to replace it with a 2017 Kia Sorento platinum.
Does anybody have any experience/advice with this particular make?
UTE042_NZ
New Zealand
MY17 Magnum Ute
30 Seconds Mould Off from Bunnings. 1L spray bottle for under $15.
