The rattle n skweek is gone
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by 88GreenVN, Oct 3, 2006.
  1. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    I did 4 things today and the sweek and rattle is gone. - for now!!
    (It sounded like it was comming from the left front door. I took trim of the other day skweek still there - trim back on.)
    1 Put grease on the bonnet catch - it was dry
    2 CRC on the bonnet hinges - not tight but just in case
    3 CRC on the links to the sway bar - dont know what they are called
    4 Masking tape on the kick plate and door seal front left door only.
    Very happy.
    Next I'll remove the tape and see if the skweek comes back.
  2. 88GreenVN
    Surprise, Arizona
    If anyone else has fixed a skweek or rattle in a vn/vp it would be great to read about it....
  3. Morton
    Morton For external use only
    Fairstar the Funship
    That gives me an idea, actually... I may rub some grease into my bonnet pin and spring, to help it slide back and open more easily. I spent a whole day pulling back and tightening the bonnet cable after it slacked right out, so it'd be nice to keep it crisp :)
    My bonnet's a little off to the right, so the pin doesn't slide straight in/out of the latch. it rubs heavily on the side... so maybe some grease will help it out. Will let you know :)
  4. 88GreenVN
    Surprise, Arizona
    Undo the pin and move it over a bit eg 3mm out of alignment - move pin 3mm. See how ya go.
  5. 88GreenVN
    Surprise, Arizona
    Removed the tape from the door seal for the trip to work and no skweek. Thats travelling down Commercial Rd Pt Noarlunga South - (that road will make anything skweek).
    So it looks like the bonnet spring may have been it...Just add some grease!!!
  6. Morton
    Oh... I can move the pin? Popping downstairs now. brb :p
  7. Morton
    bah. I think I'll need a bigger wrench :p I assume you mean unscrewing the pin from the underside of the bonnet? Bastard's too big. Good thing they built a Bunnings down the road from my place...
  8. 88GreenVN
    Surprise, Arizona
    Nothing like a bigger spanner A!
  9. 2greedy
    2greedy VP Calais (SSV)
    Queensland
    VY SS HBD6speed manual 5.7ltrs of manual GRUNT!!!
    Well iv'e got this annoying bloody rattle in the driver side door does anuyone have any ideas? it's more like a creeking rattle?
  10. 88GreenVN
    Surprise, Arizona
    Could be the door seal. I chased a squeeking in my door for 6 months. 2" masking tape over the kick plate and seal ='d squeek gone.
    Should replace the door seal if that shuts it up.
  11. adam69
    adam69 Banned
    VT Clubby
    i have greased the pins that hold the door trim on and it has taken some noises away.
  12. 88GreenVN
    Surprise, Arizona
    You put some grease on the door trim pins. I didnt think of that one! Are your door trims loose? My door trims appear to be very snug. (have re-glued the pins many times before)
