304 The time of my life.
Morton
For external use only
33
Fairstar the Funship
The WORST time of my life, that is.
Keep in mind, I havn't touched ANYTHING. This is how my engine has been running since I purchased it:
I have double, triple and quadruple checked. My motor is at true TDC. The dizzy points to cyl1, and when I crank the engine by hand, the next valve to open on cyl1 is exhaust.
Can somebody explain to me why the front of my engine reads like this, at true TDC: o_O
And I've checked - when I have the two "timing marks" or "dots" 9 links apart on the oil pump side, the dizzy points to cyl4 (fake TDC, about to intake and compress on cyl1). And no, those "bright links" never line up with the timing marks.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
can you get the dots to line up like the blue ones
Morton
33
I'm PRETTY sure the 304 isn't a dot-to-dot motor. And no, I can't :p
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
looks like its 2-3 teeth out on the lower sprocket if you use the 9 link theory
vq rat
vq rat
hamilton vic
vn bt1 burnout weapon
Right the dots need to be on the passenger side of the motor and its 9 links between dots, the cam dowel pin needs to be on the drivers side too, if you have a repco store that you go to i recommend a book to get its a max ellerys book called how to rebuild and hotrod Holden v8 the part number is ep.hv8 a great book very detailed and lots of r and d work gone in to maken the book i have had it for years and get to go back and look throw if ya not shore on something
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
so its obviously set correct then if the marks line up 9 links apart on the oil pump side its probably to do with the difference between carby and efi cam lobe differences or something silly
vq rat
vq rat
hamilton vic
Carby should be the same i reckon as the 5ltrs still have the fuel pump drive on them running of the front of the cam gear
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
yeah but the inlet exhaust valve order of the lobes is different
Morton
33
I know that mate, I know exactly how it should line up.
BUT when I do that (set dots on pass side, 9 links etc), my dizzy points at cylinder 4, and my next stroke on cyl1 is intake/compression. It's not true TDC.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
its still timed right though just odd its timed on No4 tdc fireing
