lout
- May 13, 2006
- 5,544
- 4,250
- 113
- Age
- 60
- Location
- Langwarrin Victoria
- VXii Executive V6 , VYii Adventra LS1
have a read of this
Assuming you also replaced the chain tensioners and guides, then all should be good mechanically good. So yeah, not likely the new chains have streached again (if they are from a reputable shop) so i'd say you have another issue... maybe sensors, maybe something else...Thanks for your replies, didn't really answer the question i asked. The codes come up the engine doesn't go KAHBOOM straight away there must be a period of time before it does. Hypothetical question really.
yep, i thought i saved the link but could not find itI've seen another GM TSB on the issue @lout mentioned and it provided an in car inspection methon without needing to drop the sump. I'll see if i can find it and post a link...
i have what i can only describe as as screech for a second when i start my engine, is this likely to be a timing chain issue?The chains don't suddenly go and the engine go 'kahboom', unlike what can happen with timing belts... the misinformation surrounding these things is astounding.
No funds, then park it.
Could be just one of the accessory belt pulleys.i have what i can only describe as as screech for a second when i start my engine, is this likely to be a timing chain issue?
Chain tensioners sound like a rattle at startup. My SV6 does it in winter until the oil gets up to the tensioners.Sounds more like a chain tensioner sound, especially if it disappears after a second or so. The tensioners need oil pressure to operate hence the lag at cold start.
