The top 10 everyday things people do to ruin their cars
Discussion in 'The Pub' started by The1985divo, Oct 6, 2008.
  1. The1985divo
    The1985divo Active Member
    VF Calais V
    [FONT=&quot]The top 10 everyday things people do to ruin their cars... :bang:
    [/FONT] [FONT=&quot]1. Not Using The Parking Brake[/FONT]
    [FONT=&quot]Yes, that mysterious device that you’ve never used is actually valuable. When you park on an incline, or even on fairly steady ground, without using the parking brake, you’re putting all of the stress of the car on your transmission. The only thing inside that transmission holding your car steady is a little pin called a parking pawl. By using the parking brake, you lock up the non-drive wheels as well as the drive wheels and take the stress off of the transmission. It’ll add years of life to your cars transmission. Just remember to disengage it before you start driving again.[/FONT]
    [FONT=&quot]2. Not Coming To A Complete Stop Before Shifting[/FONT]
    [FONT=&quot]So you’re in a rush, and you pull out of a parking space and shift into drive while the car is still coasting backwards. You’ve just added months of wear to your transmission in seconds. Inside your transmission is a complex set of gears, when you shift without stopping like that, you’re asking those gears to work as your brakes, which puts an amazing amount of stress on such a small area. You can also damage your drive shafts, the things that send power to the wheels, by shifting that way. After a while, it’ll lead to sloppy suspension handling, and a worn out transmission.[/FONT]
    [FONT=&quot]3. Riding The Brakes Down A Hill[/FONT]
    [FONT=&quot]If you are driving on a hill that goes on for a while, you’ll want to avoid riding the brake the whole time. Alternate between braking and letting off the brake so you don’t heat up and wear out your brake pads. It’s a common mistake, because it feels like the safest way to maneuver down a hill, but if the hill is sufficiently long, you can end up almost totally wearing out your pads, since as they heat up, they wear faster. [/FONT]
    [FONT=&quot]4. Forgetting To Change The Oil[/FONT]
    [FONT=&quot]You need to change your oil every 10000ks at the most. That’s really all there is to it. I actually read a blog online that said you can wait until your oil light comes on to change your oil. I’ve worked in the automotive business… by the time your oil light comes on, the oil inside your engine has turned into jet black molasses and is of no use to your engine. In the short term, I suppose it’s not that important, but more frequent changes can actually double the life of your car and greatly increase its performance. [/FONT]
    [FONT=&quot]5. Pressure Washing The Engine[/FONT]
    [FONT=&quot]I can respect a person’s desire to want a clean engine. It gets grimy under there and a guy with a pressure washer is a dangerous thing for grime - you want to point it at anything even slightly dirty. But a grimy engine that runs right is better than a clean engine that doesn’t run at all. And if you spray a high powered jet of water around rubber seals and hoses and electrical bits, you’re bound to dislodge something important. A modern engine is a complex thing, all manner of sensors and wiring harnesses and components, and it’s no place for a jet of high pressure water. A regular garden hose is OK if you want to wash it down, just be careful with the high pressure business.[/FONT]
    [FONT=&quot]6. Starting Your Car The Wrong Way[/FONT]
    [FONT=&quot]It seems simple, but you can make a big difference by turning off your radio, wipers, climate control, all of those accessories, when you start the car. Most of the wear on the engine happens when you start the car, and by turning off those accessories, your engine doesn’t have to work as hard when starting. [/FONT]
    [FONT=&quot]Another thing people do is revving the engine in the winter. This actually doesn’t help “warm up” the car. Although it does technically make the engine hotter, it’s not the kind of “warming up” that you want. Revving your engine in the winter causes extreme temperature changes right away, which is actually the opposite of what you want. When you start the car, the oil hasn’t yet worked its way through the system, so the engine is working without lubricant. The right way to do it is just let the car sit and idle for about 30 seconds to a minute at the least. [/FONT]
    [FONT=&quot]7. Ignoring Your Car’s Sounds[/FONT]
    [FONT=&quot]Every sound your car makes means something, if you pay attention, your car can usually tell you exactly what needs fixing. Those squeaking brakes mean you need new pads, and if you ignore that sound, eventually you’ll hear scraping metal, which means you need new rotors, and if you ignore that, you’ll eventually hear the sound of your own scream as you lose your brakes completely and fly off a cliff in a spectacular fireball of death. It’s more common than you think. Listen to your car. [/FONT]
    [FONT=&quot]8. Letting The Interior Go[/FONT]
    [FONT=&quot]You’re in a rush again, and you eat most of your disgusting egg and cheese bagel, and toss the rest in the wrapper on the passenger seat. Lovely. You know who you are, you’re car is filthy, never been vacuumed, 15 air fresheners hang on the mirror, and yet, no air freshener made by mortal man can stop the sickening wind within your car. You need to clean it. If you don’t vacuum your carpets and clean out the garbage every so often, you’ll develop a smell that is impossible to destroy. I’ve worked in the auto salvage business, and I know that there exist smells that are so obscene, so inhuman, that no shampoo can vanquish them. The only way to stop them is to never let them develop. Clean your car, for the sake of all mankind. [/FONT]
    [FONT=&quot]9. Running Your Car Down To Empty[/FONT]
    [FONT=&quot]There’s actually a bit of a debate about this one. The old wisdom says if your car gets down to E, the sediment in your tank will get sucked into the system and foul your fuel injectors. Although some mechanics says thats not true. Either way, running down to E does pose other problems. You cut the life of the fuel pump considerably, since the fuel actually cools the pump. [/FONT]
    [FONT=&quot]An interesting note: Most cars can drive another 60 kms+ after they hit Empty, automakers call this extra fuel the “buffer zone”. US cars have the largest “buffer zone” of any vehicles. German drivers, for instance, like to know exactly how much fuel in is the car, so their “buffer zone” between the gauge’s E and the actual empty tank is much smaller. [/FONT]
    [FONT=&quot]10. Driving Past Attractive Women[/FONT]
    [FONT=&quot]This is a common mistake, especially among younger male drivers. Attractive women can be incredibly damaging to your vehicle, they can cause the driver to install bizarre over-sized woofers or 22 inch rims, or even spontaneously crash the car into a nearby tree or telephone pole. When you’re driving, be careful to avoid swimming pools, beaches, college campuses, anyplace where beautiful girls assemble in any significant numbers. Your car will thank you.[/FONT]
  2. calais_304
    calais_304 New Member
    98' VT Calais s1 - 195i
    i'll add checking water to that list...lol the new missus just cracked a head cuz it was dry, think i better start teaching her the basics :p
  3. Astranomical
    Astranomical Ecotec just kicked in yo
    Dee Why, NSW
    Hammerhead Eagle i-Thrust
    Its amazing how many people mistreat their cars, 3 and 8 are especially rather common, as is 10. :p
    Btw, welcome back Salem! :)
  4. VL_5SPEED
    VL_5SPEED New Member
    Newcasstle
    1986 Holden VL calais project
    7. For me. Gearbox has made a knocking sound since I got the car.. Apparently thrust bearing. I blew the ****er up on friday lol.
  5. The1985divo
    VF Calais V
    Lol..thanks, havent really been gone, jus lurking round the place :wax:
  6. Bax
    Bax Projecting
    QLD
    Nothing
    hahahahaha
  7. blacknight
    blacknight New Member
    VX Executive
    the part about driving past women is so true. lots of times i swerved off the correct lane coz there's always some hot mama jogging with her kids...
  8. Evolution_Ends_Here
    Evolution_Ends_Here New Member
    Dandenong North
    Miitsubishi Magna TJ
    gt8 post, mine would 3 & 6
  9. Torquen
    Torquen Boost FTW
    Perth, WA
    450+ HP FORD XR6T
    but mad woofers and 22' DUBS make ya ride full sick uleh, and what am i ment 2 do with me kebab wrapper bro? :p
  10. commsirac
    commsirac Banned
    vx
    A lot of things I dont agree with in the list, the ^ being one of them. I think most people realise that putting the car into park and letting it roll onto the locking mechanism is a no-no, when they cant actually get the car out of park again.....whether it causes any wear to the transmission.....I doubt it.
    Parking brake on the non drive wheels, front wheel drive commodores.....help!
  11. Full Spectrum
    Full Spectrum Bro it's a VW your Audi!
    Berlina V6
    Top thing.
    Driving it. Most shouldn't bother.
  12. Full Spectrum
    Berlina V6
    Top thing.
  13. levymetal
    levymetal TURN MY HEADPHONES UP
    Somerville, Victoria
    HSV ENHANCED VP CALAIS
    parking brake only locks rear wheels (in a commodore anyway)! also with the running on empty, i doubt you 'suck up all the ****' because all the '****' would be at the bottom, which is where the pump gets it's petrol from all the time anyway! so the **** is always getting sucked up. but i blew my pump driving it on empty so it's still not a good idea.
  14. commsirac
    commsirac Banned
    vx
    I think that what you can say with confidence is that the material that has fallen to the bottom has already been sucked through the system and/or trapped by the fuel filter.
    Its the material(heaps of stuff) that actually floats in petrol that is the problem and this is the stuff that you will start sucking through when the level runs low.
  15. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    Next time you plan on ripping off someone elses write up... at least do it on a differnt day.
    Credit the original author.
    The Best Article Every day | Bspcn.Com
    aZk.
  16. klaw81
    klaw81 New Member
    Toowoomba
    VYII SV8
    This is utter bollocks - most cars brake either the front OR back wheels, not both. It's actually law that manual cars have their handbrakes engaged while parked though...and that's not a bad thing.
    I drive up and down the Toowoomba range every day for work, and it's amazing to see how many people ride their brakes from top to bottom. Some people are just clueless.
  17. The1985divo
    VF Calais V
  18. Juztin
    Juztin Donating Member
    Knox region
    VY II SS UTE Auto
    Very nice information there.
  19. VSIIISU
    VSIIISU New Member
    VS III S Yewt
    Your car will definitely thank you if it has a brain, eyes and a heart. Fortunately, such things do exist but unfortunately they do not function in the manner we assume :) Maybe a good indication for one whos on their way to mechaphilia :rofl: ;)
