Surly removing the headlights would be easier??
(MR16 LED downlight bulbs for halogen house lights are worse)
I very much did mate thank you, swapped out the Low Beams today. My fingers bloody hurt!Bump... post complete... hope some VF owners find this useful
Crikey. You'll be doing it again in a year or so most likely.I very much did mate thank you, swapped out the Low Beams today. My fingers bloody hurt!
I had to remove a few additional bits in order to get access to twist off the dust covers (working on an SS LS3):
Drivers Side:
- Coolant tube
- Fuse box cover
- Dual wiring loom (coming out from the fuse box) that's mounted on a white clip behind the high beam dust cover
Passenger Side:
- Air box
On the drivers side, I ended up removing the top 2 screws of the headlight unit to get a bit of wriggle room. Didn't need to for the passenger side - Once the air box was out I had tons of room.
