Such LED lights are illegal if used in housings not designed for this type of light source. Also, I recall correctly, where a light source puts out > 2000 lm, the housing needs a self leveling feature which halogen housings do not have (presumably presumably because output is < 2000 lm )...And while I'm here has anyone had a go with these or something similar?
Led halogen H7 replacement
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com.au/ulk/itm/232539042998
They dont look too legit and look awefully bright the ones in my post are legal as the top most limit of what is allowed in NSW roadsAnd while I'm here has anyone had a go with these or something similar?
It could be the type of led you used. I cannot vouch for anything else other than what i know ive used from bling. However yes maybe a fuse went, i do recall replacing a couple fuses before but i cant recall for what reasons.Changed over just the front reading light in my 15 Sv6 to a led one. Only had one at the time. So now I have a bag of ten I tried to change both to the new ones and now my front won't work. Tried the old one, that won't work tried the old old one and that won't work. Should I be assuming a fuse problem
