thermo fan help
holden123
adelaide
commodore VX SS SII
hi can someone tell where the thermo fan switch/sensor is on vn s2 i cant find it thanks
Pub247
Melbourne S.E.
Ford Fairmont
try the passenger side footwell behind the kick panel. It's called an ecu :)
also if your have drama check relay in engine fuse box.
best way to test if your fan is working is to put the ecu in diagnostic mode once in that mode and ignition on the thermo should come on if not then there is a fault with the thermo or wiring to it
