vylover
- Jun 14, 2012
- 189
- 0
- 16
- Location
- Ermington
- VS Manual Ute
Hey guy's, I have recently noticed that in drive thru and in heavy traffic my car is very quick to heat up..
The low speed thermo fan would never kick in so I usually just keep the A/C on (and It really ****'s me because the A/C does not even work so I'm still boiling hot and need the window open) but anyways.. usually have the ac on and that keeps the fan spinning and its all sweet but just recently the ac does not even turn the fan on.. yes at about 3/4 temp gauge the high speed cut's in but its not good enough and I don't want it to get really hot so quickly and even keep at that temp because high speed keeps kicking off once it thinks it will be ok :/ Anyways... tried removing the temp sensor and starting the car but no fan came on... (I think the temp sensor is right near the thermostat housing just below, right??) and yeh no fan at all...
Just want to know if anyone has had this problem because everyone else's say's that theirs works with ac..
Im sweet to hard wire it with a switch in cabin if you guys think it will be a bitch to do but if it is a cheap fix i might fix it no?
Thank's in advance,cheer's guys
P.S I put 3 core aluminium 52mm radiator in with good nulon coolant so i don't know if that makes a difference? been in a while now so if anything if it was that then the fan should have ####ed up ages ago no? cheer's again..
