can't seem to find a specific answer for my problem, so here goes been hot lately (today was 30 degrees C!) and the temperature keeps rising toward middle, then dropping to 1/4 i stop they car, leave the engine running, temp is at 1/2 and i notice that the thermo fan isn't moving but it does in order to lower the temp am i right? how can i check it still works and that it's not broken? and that it comes in at the right time? time for a new one? thanks
M8 i had this problem the other day and it turned out to be 1 of 2 things the relay under the bonnet and 1 of the fuses in the vehicle.
Yeah, common problem - agey relay - make sure you get the correct part number from Bursons or Holden etc.. Yep good hint is to check the horn relay. Cheers AP
