no man - the theory of the brainstorm was more volume and cooler air flowing through the air intake with the addition of a fan - not seeking better engine cooling....
Have another drink :yeah:
Fans no good for air intakes or they would have fitted them as a standard item long ago.
K+N type free flow filters and some nice ducting to the front of the car like just behind front lip are good starters....
The airflow difference between a pod filter and its equivilent panel counterpart is S.F.A that you would never notice in everyday street use!
Pods are waste of time unless you are going to fark around making a cold air box to go around it to keep engine bay heat out.
A suggestion for carbie 202 owners have a look at these:
http://oldholden.com/ohfiles/images/Completed Weber Conversion.jpg
and
http://oldholden.com/ohfiles/images/Weber Throttle bracket close up.jpg
Uses a webber carb and air intake from a coon and use a K+N element. Can then pipe a CAI pipe from the front to the air cleaner housing.
Cost maybe $60.00 all up?
