Thermo fans running all the time
Getthebook
53
Vs Commodore UTE series 2 3.8 v6
I have VS ute 3.8 v6 factory air. When I purchased it was told the a/c was working but had stopped. A/c currently does not engage but I think it’s out of gas anyway
I found the wire to the compressor ( 1 wire) was broken so proceeded to re solder on to resolve the issue
Still nothing and the fans run as soon as you turn ignition on hot or cold
Reading another forum as suggested I replaced the ECU sensor in the thermostat thinking this may sort out but still the fans run
I have tested computer with pin 5 and 6 and it comes up with 12 no errors
I have no current to the a/c compressor but was told due to no gas it would not switch on
Checked all fuses and relays
Lost where to look next. Your help would be greatly appreciated
BlackVXGTS
Melbourne, SE
Attached are diagnostic charts from the Holden VR/VS Service manual which may help you with your problems (or may just flood you with too much information LOL).
  • VS V6 PCM AC Clutch Control Chart A-11.1.pdf
  • VS V6 PCM AC Clutch Control Chart A-11.2.pdf
  • VS V6 PCM Electric Fan Control Chart A-12.1.pdf
  • VS V6 PCM Electric Fan Control Chart A-12.2.pdf
  • VS V6 PCM Electric Fan Control Chart A-12.3.pdf
Getthebook
53
Thanks the flow chart I will try tomorrow but the first three steps sound like my exact problem
Getthebook
53
All good followed flow chart turned up a faulty or wrong BCU l
Considering my ute key has a boot open button and it’s a ute it seems to have been replaced at some time
How do I know the correct bcm or the car??
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
That would signify that you have a Berlina or higher level BCM fitted, but that's highly unlikely and I'm pretty sure not possible. What you'll find is that many 2 button keys are now replaced with 3 button key blanks and programmed to suit. this is becoming quite the norm for the key retailers to just keep stock of one type of blank. My sons VS Exec had a 3 button key added to it by the previous owner along with the original 2 button key that came with the car when we bought it for a whole $300. This car still has all it's original gear fitted along with its original BCM.
Getthebook
53
Many thanks you blokes are on the ball. I called Holden and got the part number based on the original vin number that directed me to a different BCM. Local wrecker had one so bought it for 50 bucks. Will advise outcome but the low fan control on your suggested BCM is where my problems are. Fingers crossed and will update when it arrives
vs-lover
I hope you got a key head with the BCM, if not it's a useless boat anchor and not worth fitting.
Getthebook
53
Yes mate got the key fob. Am told as it’s a series 2 I don’t need to touch the ecu or program it like with the VT ‘s
Jury is out but hopes are high
Always return for a refund ( love Paypal) otherwise will post if anybody needs a boat anchor ⛴⚓⚓
EYY
VS Statesman
Yep that’s right, don’t need to link anything. Plug in, change your keyhead and go.
Have you tried replacing the fan relays too? Contacts can sometimes become stuck in the closed position.
