thermo fans
v8commy
Banned
reynella sa
vk calais 5.0
getting a 140a alternator today so i wanna put in some thermo fans anyone have suggestions on what size and or what cars i can get some off or where i can get some cheap all help is appreciated
philbio
VK + VY Gas Cars
I picked up a set of brand new mondeo style fans off ebay, came with relays,fuses and all wiring required.
MICKY.D
MELBOURNE
VE SV6
I have used a single 16" davies craig thermo with their controller unit, worked great on my 5.0L with our supercharger fitted on her, never went over 1/4 on the gauge.
Or
VT or AU :)shooting: FORD) twin thermo's from wreckers??
Cheers :thumbsup:
Micky.D
YT
philbio
VK + VY Gas Cars
Twin 12" offset.
v8commy
Banned
reynella sa
vk calais 5.0
what about vt do they bolt on or clip on or do i have to modify them
philbio
VK + VY Gas Cars
Start using the search function on the forum, it's all there. :)
ari666
250,000 hits
craig davies make two great fans which are 16 inch and you offset them so the whole radiator is covered, then you can ditch your shroud.
mine are currently set up-stream, which is on the engine side of the radiator and sucking the air through, but they recommend you set them down-stream and blowing. they are pretty expensive though.
v8commy
Banned
reynella sa
vk calais 5.0
well im picking up a set of el twin thermo's today who knows how to mount them apparently i cant use the pull through radiator clips (like zip ties)
philbio
VK + VY Gas Cars
el are too big for VK. The fans hang over the edge of the radiator and you end up pulling air through the sides instead of through the radiator.
