thermostat housing
90VN55
34
stanthorpe, qld
90 VN SS 5speed, '90 VN Calais 5speed
i have just replaced the thermostat and put it all together and a bit of coolant is squirting out where the theremostat meets the engine. is there an easy way to fix this or do i have to rip it all off again?
p.s. i put a new o ring on aswell
xcop5l
4th year spanner spinner
ol' geelong vic
VN ex cop 5L
that usually means the thermostat isnt seated properly or the gasket hasent seald yes you will have to pull it off again
90VN55
34
stanthorpe, qld
so there is a gasket?
the bloke from holden said there is none:bang:
90VN55
34
stanthorpe, qld
mines different it has a O-ring
90VN55
34
stanthorpe, qld
mine is a series 1 so the housing is at the back of the engine under the throttle body.
and there is only 1 bolt to hold it on
AirStrike
91' VN SS
Unless the V6 is different xcop5l, cause I know the 5.0lt is a gasket........
AirStrike :air:
90VN55
34
stanthorpe, qld
here are some pics
