thermostat replacement VZ SV6
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Blue SV6, Dec 5, 2008.
  1. Blue SV6
    Blue SV6 New Member
    2005 VZ SV6
    I seem to be having thermostat troubles (seems to be sticking or operating intermittently) and have purchased a new thermostat and housing.
    I have been told that to replace the thermostat in my 2005 SV6 I need to remove the gearbox to get at it.
    This seems like a lot of work to replace a simple part, particularly when it is so easy to get at in other vehicles.
    Is this the case?
    If it is the case, should I try to reverse flush with a hose as it may be be something stuck which is effecting the operation of the thermostat.
  2. Farlig
    Farlig Member
    Y-Series Clubsport
    yup this is true, the alloytec is one shiet engine lol, change spark plugs requires removal of manifold, gearbox removed to do thermo, and shiet dual mass flywheel lol. not an easy engine to work on hahaha fun times.
  3. Blue SV6
    Blue SV6 New Member
    2005 VZ SV6
    Thanks, I think. Glad I've got the alloytec!
    I might try reverse flushing & see whether it improves.
    The temp. gauge flickers between 1/4 & 1/2 but coolant in reservoir isn't overhot.
    Sounds to me like thermo.
    What do you think.
  4. IPCOlsenVZ
    IPCOlsenVZ Member
    05 VZ Commodore Equipe
    I had a look in the service manual and you have to take off the manifold and a few ignition components and disconnect the engine harness to transmission harness but from what I’ve read, removal of the transmission is not required.
  5. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    my temp guage sits just above 1/4 as do all other vz's, goes up probly 1-2mm if sitting in traffic or a hot day,
    i dont believe you have to remove the transmission aswell, you should get it from working over the top of the engine,
    oh and alloytecs definetly arnt the worst to work on, how about lifting the enigne up on a late model subaru to do spark plugs anyone?
  6. jsd
    jsd New Member
    VZ Calais
    My thermostat stuffed up the otherday all fixed now and not overheating anymore!
  7. Summer-Sickness
    Summer-Sickness 2005 VZ EXEC
    Rockingham, Perth
    05 VZ Executive
    howd u go with this? i think my thermostats stuffed so im gonna have to get into it next weekend.
  8. muzzcat
    muzzcat New Member
    Tooradin
    vz wagon
    yeah mate i just did mine didnt take tranny out or manifold off just hade enough room took me bout 6 hours dont think i would do it again BIG JOB!!!!
