losh1971
- Jan 17, 2010
- 22,585
- 22,318
- 113
- Location
- North Tas
- VE Series I SS Ute
I have had three failed pumps in 3 years. Anyone know what is going on. Each pump has leaked from the weep hole. I have had two failed brand new GMB's and now a failed Gates. Also the original GMB that was fairly new when I bought the ute, failed within six months of ownership.
To get my Gates replaced under warranty I have to send it to Qld. This will mean three weeks with no replacement pump unless I buy another one. I am actually considering fitting a SH one from the donor because four or more weeks without transport is going to suck. This Sunday will be one week that it has already been off the road. I only found the pump leaking when I removed the rear fan to make working on the engine easier and saw the drip right under the hole running down on to the CAS cover.
The old bus has had the coolant dumped no less than seven times. The coolant is near new and I am now catching and reusing because it's never ending and a waste of 40-50 bucks worth of coolant if I chuck it each time.
