This might be a stupid question...
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by st3r3otyp3, Feb 15, 2008.
  1. st3r3otyp3
    st3r3otyp3 Donating Member
    WA bruz
    VX HSV VX SS
    What is a knock sensor, what does it do and where exactly is it located on block. :whistling
  2. Harvs82
    Harvs82 Active Member
    Glen Waverley VIC
    MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
    Its part of the ignition timing, basically it listens in the engine for pinging, or pre detonation of the fuel air mix before its meant to burn... Pinging is pretty bad for the engine, so this sensor basically keeps an eye out for any signs of pinging or knocking, and if it detects some, then the timing is retarded. On the VS there are two knock sensors, not too sure about the VR engine though. On the VS from memory they are in a difficult to get to spot behind the exhaust manifolds, I think.
    Again on the VS engine, if you have the engine running, and give the metal bracket that holds the alternator in place a quick sharp belt with a hammer, you should hear the engine revs dip momentarily, this is because the sound of pinging is the same as the sound you make with the hammer, and the knock sensor 'hears' this sound, and thinks the engine is pinging/knocking and then retards the timing to suit... just a good way to test that its working anyway.
